TBS6522 Webui Tutorial on Using DVBS and DVBC Simutaneously!
Postby Jenny » Thu Aug 04, 2016 4:00 pm
Dear All,
Nice day for you! :) Here is an awesome video of TBS6522 Webui Tutorial and How to Use DVBS and DVBC at the same time!
https://youtu.be/hSc_lQ-kVZo
New Arrival TBS6522 Multi-standard Dual Tuner PCI-e Card supports multiple digital TV standards including ISDB-T/DVB T2/C2/S2X/S2/T/C/S and enables you to watch TV channel from one transponder/satellite while recording another channel from other transponder/satellite at the same time.
TBS6522 can be used for data receiving, IPTV streaming, media monitoring and digital content distribution.
The Four RF INs are independent with each other. With this multi-standard TV tuner card, a switchover between different digital TV signals is much easier to operate. you just need to plug another signal cable instead of taking out the card from your server. With two tuners, TBS6522 enables you to use DVBS and DVBC at the same time!
For more details, pls see http://www.buydvb.net/tbs6522-multi-standard-dual-tuner-pcie-card-p-148.html
TBS6522 Windows Driver
http://www.tbsdtv.com/download/document/tbs6522/tbs6522-windows-driver_v1.0.0.2.zip
TBS6522 Mode Change Tool
http://www.tbsdtv.com/download/document/tbs6522/tbs6522_changemode_tool_v1.0.0.1.zip
DVBdream
http://www.dvbdream.org/
Thanks for your attention and support. Any feedback would be much appreciated! :)
Best Regards,
Jenny
TBS Technology
Jenny
