[ Moderator Control Panel ]
by aitorle » Thu Jun 02, 2022 1:42 pm
hello all I'm using TBS 5580 for few months now. there has always been a problem of very hot temperature. usually I shut it down and restart, which helps. strange noises from the device is another issue. but from last some days it's behaving strangely. it simply does not power on.
I'm using it with ubuntu 20. is the device expected get so hot? also the noise? why does it stops working sometimes? plz reply
thank you
aitorle
by smile » Thu Jun 16, 2022 2:40 pm
Hi sir
maybe something wrong with the hardware. please contact after-sales service.
Best Regards
smile
by aitorle » Sun Jul 10, 2022 5:33 pm
smile Wrote:Hi sir
Best Regards
Could you please explain how to contact after sales service? Is there any service center in the Netherlands for TBS products?
aitorle
