Use of TBS5520 with satellite operator's set top box?
Postby tosem » Wed May 02, 2018 2:59 pm
Hi everyone,
This is the situation: I have a subscription with a satellite operator. In the summer, I go on vacation in a remote place where I have a trailer with a satellite dish. My question is: can I plug the operator's set top box into the TBS5520 in order to watch the channels on my laptop, since I don't have a TV set in the trailer? Thanks in advance for your answers! :)
tosem
Re: Use of TBS5520 with satellite operator's set top box?
Postby steven » Thu May 03, 2018 11:09 am
Hi tosem
What about the channels is it FTA ? if yes then you can use this box to watch the live channels with the DVB application
Thans
Postby tosem » Fri May 04, 2018 2:03 am
No, that's the thing - I'm aware I can use it to watch FTA channels directly. My question is, whether I can use it to watch the coded channels of the operator by connecting the set top box with the operator's card to the TBS5520 and from there - to the laptop? If I connect it to the cable/terrestrial input, for example, will it display the channels through the tuner, like through a regular cable service?
tosem
Postby steven » Thu May 31, 2018 11:14 am
sorry that for encrypted channels you can not watch by 5520
