TBS5520 on Raspberry PI
Postby QTIP » Wed Dec 14, 2016 4:17 pm
Is it possible to run the tuner on a raspberry pi?
I would like to use it with TVheadend.
I installed Raspbian on the raspberry. Followed the instructions in the readme file.
which architecture should i choose..Or is the driver not compatible with the ARM architecture?
The make and make install commands are not successful
QTIP
Re: TBS5520 on Raspberry PI
Postby QTIP » Mon Jul 03, 2017 7:59 pm
never mind. osmc is working fine.
QTIP
