TBS2603 UNABLE TO DOWNGRADE.
Postby sostost » Tue Jul 08, 2025 4:35 am
I am trying to downgrade to a lower firmware but it doesn't work. Is there a way to fully reset the machine via telnet?
Thank you.
sostost
Re: TBS2603 UNABLE TO DOWNGRADE.
Postby daowei » Tue Jul 08, 2025 10:39 am
sostost Wrote:Hello,
Thank you.
Hi sostost,
Yes, it's possible to downgrade.
And yes, if downgrade through web GUI does not work, we can do by telnet. Means upload the firmware file on web GUI first, and then login to
Encoder system to upgrade by Telnet.
You can e-mail me "daowei@tbsdtv.com" when you're ready to do "downgrade", i'll guide you how to do.
