FW 1.1.96
FW 1.1.96
Postby webmotions » Sun Jun 02, 2019 1:24 pm
What did you fix with this version?
Any news about faacebooks RTMPS (secure protocol) support?
webmotions
Re: FW 1.1.96
Postby daowei » Thu Jun 06, 2019 11:31 am
For RTMPS, i'll talk with my software Engineer, maybe not so quick to support.
We have another model named TBS2605, it already supports RTMPS, and also supoprts 4K_30fps (same as TBS2604). And even TBS2605 supports 2-channel 4K per unit. You can have a look:
https://www.tbsdtv.com/products/tbs2605 ... coder.html
Re: FW 1.1.96
Postby DrCool » Sun Jun 23, 2019 8:55 pm
Sorry to say that FW 1.1.96 gives me periodic (about every second) jerking movements. image freezes briefly and jumps ahead to the correct frame. I reinstalled FW 1.1.87 with my usual parameters and everything is fine again.
DrCool
Re: FW 1.1.96
Postby daowei » Thu Jun 27, 2019 10:48 am
Which protocol you're testing? all protocols have this problem?
For RTMPS, maybe we'll add support in the future.
Re: FW 1.1.96
Postby nixs » Wed Oct 02, 2019 1:58 pm
Hi.
I have a problem with this firmware, that for some time when it starts I cannot view any of input HDMI (first or second).
I tried to disable second - the same. One thing I must do to work is just click APPLY (whatever which bookmark) not changes anything.
What am I doing wrong? Maybe any of the option?
And one question: how many connection could be at the same time to one stream? Is there a limit?
thnx for any advice.
nixs
nixs
Re: FW 1.1.96
Postby iie » Tue Oct 08, 2019 11:03 am
nixs Wrote:Hi.
nixs
I have the same problem please give
iie
Re: FW 1.1.96
Postby daowei » Thu Oct 10, 2019 9:34 am
Hi nixs,
So maybe you can install back to older v1.1.87 first, we'll check why v1.1.96 not working well.
For the connection, the limit is about 10. Becasue this is based on ARM platform and for source device capture only, not a Server, can't handle so many requests.
You can Encoder---IP out----import to encoder stream to these softwares which supports "concurrent requests" like Flussonic, and ect.
