whats the optimal settings
Postby Tictalk » Fri Sep 16, 2016 5:11 am
for streaming live hd
i can get it working but when i maximise the screen its choppy or blurry
can someone post a setup thats nice for stream live hd :mrgreen:
Tictalk
Re: whats the optimal settings
Postby freddy12 » Fri Sep 23, 2016 5:07 pm
also want to know
freddy12
Postby Alegpl » Fri Sep 23, 2016 9:10 pm
I keep default parameters, except:
vbr
size auto
bit rate from 500 to 12000
from my experience, with ethernet I can use also 12000. with wifi max 6000 but it depends
audio with maximum quality
h.264 or h.265? depends also here. If I want to stream over internet, h.265 with 1000 bitrate (watchable also 300 or 500 in case of emergency but .... depends by bandwidth)
h.265 is ok with "modern" cpu because if you have a gpu with hardware decoding it's good, otherwise you will load way more your cpu warming the enviroment around (a "real" problem only for laptops)
anyway h.265 is more or less 3 times better than h.265 so 1 Mbit h.265 = 3 Mbit h.264
Alegpl
