Connect TBS2603 to Wowza not working
Postby pep » Tue Aug 23, 2016 1:40 pm
l've been trying to connect the enconder to Wowza treaming engine with RTMP protocol, without success, could someone confirm that it can be used with Wowza Streaming engine.
this my config:
RTMP server ip: ip of my wowza streaming engine
RTMP server port: 1935
RTMP user name: user created in Source Authentication
RTMP password: passwd created in Source Authentication
RTMP app name: live
RTMP stream name:myStream
l think my config is correct, but l have black screen. because l was help by a technician of wowza.
any help would be nice.
pep
Re: Connect TBS2603 to Wowza not working
Postby echomay » Tue Aug 23, 2016 2:39 pm
Which version of your firmware?
echomay
Postby pep » Tue Aug 23, 2016 6:51 pm
Version:
1.0.51.
pep
Postby steven » Wed Aug 24, 2016 11:31 am
Hi pep
Please have a try with this new version V1.0.59
https://my.pcloud.com/publink/show?code ... pBvmXGL4Hy
Postby pep » Wed Aug 24, 2016 3:02 pm
just tried it, but the same results.
This is what l get from wowza streamin ingine:stream or file could not be found or access was denied.
it seems that wowza can not find the encoder.!!!!!!!
:evil:
pep
Postby ebebendel » Wed Aug 24, 2016 7:02 pm
hi,
had the same problem.
After removing the "@" character from the connection pwd all works fine...
maybe you have also special characters in the password??
ebebendel
Postby pep » Wed Aug 24, 2016 8:41 pm
all my passwd are numerical.
could you show me your config from both sides, please.
without showing your user and passwd.
pep
Postby ebebendel » Wed Aug 24, 2016 11:08 pm
hi pep,
important point from my config is:
only h264 worked for me, with h265 no stream!
The inbuild dash player from wowza is not stable in my environment. i have to restart my browser to get the stream several times.
Hope this helps, attached my config:
Eberhard
ebebendel
Postby pep » Thu Aug 25, 2016 5:01 am
HI!!
thanks , l tried every thing it does not work, maybe you should show me from scratch how you managed to add your source to wowza
what ip you used with the port 43691? the encoder one or wowza server's one?
please help me to this thing working.
thanks
pep
Postby ebebendel » Thu Aug 25, 2016 4:01 pm
hi Pep
the ip adress of port 43691 is the real internet adress of the 2603 device, so not the internal 192.168.x.x adress inside your local network, but the public internet adress of your router connection.
You cannot configure/change that port, i think its dynamically set.
Do you see the incoming stream from your 2603 device within wowza? is the connection established? any log entries?
i have no special configuration outside my 2 screenshots in wowza. important thing for me was the h264 profile NOT H265
ebebendel
