2 streams not working
Postby Alegpl » Mon Aug 08, 2016 5:45 pm
Hi, I still can't use 2 streams at the same time. If both are enabled, 1st stream crashes after some time. Any news about new firmware to fix this and audio glitches?
Thank you
Regards
Alegpl
Re: 2 streams not working
Postby steven » Tue Aug 09, 2016 11:14 am
Hi Alegpl
which firmware you are using now ? is it V1.0.51? if not please have a try update to latest one
Postby steven » Tue Aug 09, 2016 11:24 am
Forget to say you can have a try with this version :
http://www.tbsdtv.com/download/document/common/tbs-linux-drivers_v160630.zip
we added kernel 4.6 support
Postby Alegpl » Tue Aug 09, 2016 3:50 pm
steven Wrote:Hi Alegpl
Yes I'm using 1.0.51. It seems to work for some minutes, then the 1st stream crashes. No problem with the second, it keeps going on.
I tried with h.264 + h.265, h.265 + h.265 and various bitrate etc etc. Same result.
Linux drivers...what can I do with them?
Thank you
Regards
Alegpl
Postby Alegpl » Thu Aug 11, 2016 7:24 pm
With audio bitrate 256000, the 1st steam neither starts. While with 96000 it works but, as I say before, only for few time.
Alegpl
