6290SE in SilveBlue
6290SE in SilveBlue
Postby JuhaFinland » Mon Feb 10, 2020 7:35 pm
Hi, there. And how to install driver to Fedora Silverblue. I want to try as Silverblue will be mainstream in the future of Fedora. VLC mediaplayer has tv card option but problem is the driver. Where to start. Anyone using already Silverblue here. What driver you recomend. The problem is that Silverblue has a diferent aproach from common Linux system. First problem is that need to have .rpm driver what can be fairly easy to install but compile out by make command is not easy at all since mature of Silverblue. So where do I get .rpm driver for a card. lspci show card and it is functional but without a driver.
JuhaFinland
Re: 6290SE in SilveBlue
Postby steven » Fri May 22, 2020 2:42 pm
Hi Sir
You can have a try with this package :
# wget http://www.tbsdtv.com/download/document/linux/media_build-2020-01-02.tar.bz2
#tar jxvf media_build-2020-01-02.tar.bz2
#cd media_build
#./install.sh
#reboot
and best setup SSH remote if you failded install the driver you can send detail information to our support
Return to DVB-T2/T/C Dual Tuner Dual CI PCIe Card TBS6290SE
