TBS6290SE CAM not working
Postby mitja » Fri Nov 10, 2017 4:53 pm
Recently I bought 3x TBS6290SE dual tuner cards. The cards are working on unscrambled channels but I am unable to decrypt scrambled channels using dvblast.
I compiled everything as per manual for DVB-C. Non ecrypted channels works, I can even see multicast traffic on my router, even of scrambled channels, but I am not able to access it, probably because are still encrypted. I've changed different CAM modules (I have three types) and all are working at my cable provider (tested by them). Do you have any hints for my problem?
Thanks.
Here is my log: https://pastebin.com/TMXLVbu6
mitja
Re: TBS6290SE CAM not working
Postby steven » Mon Nov 13, 2017 3:47 pm
Hi Mitja
Which CAM you are using ? is it professional one ? as you are decryption about 9 chanenls :
debug: conf: 239.254.1.1:1234/udp config=0x9 sid=13101 pids[0]
debug: conf: 239.254.1.2:1234/udp config=0x9 sid=13102 pids[0]
debug: conf: 239.254.1.3:1234/udp config=0x9 sid=13103 pids[0]
debug: conf: 239.254.1.4:1234/udp config=0x9 sid=13104 pids[0]
debug: conf: 239.254.1.5:1234/udp config=0x9 sid=13105 pids[0]
debug: conf: 239.254.1.6:1234/udp config=0x9 sid=13106 pids[0]
debug: conf: 239.254.1.7:1234/udp config=0x9 sid=13107 pids[0]
debug: conf: 239.254.1.8:1234/udp config=0x9 sid=13108 pids[0]
debug: conf: 239.254.1.9:1234/udp config=0x9 sid=13109 pids[0]
as we know that professional CAM support about 8 channels , normal CAM only support 1 channel with 1 CAM .
You can have a try only streaming one channel check whether is ok
Return to DVB-T2/T/C Dual Tuner Dual CI PCIe Card TBS6290SE
