Is it possible to use more than a TBS6281 in one PC?
Postby mourn » Tue Dec 15, 2020 7:30 pm
I'm trying to build a PC with multiple DVB-T2 PCIe capture cards.
Is it possible to use more than one TBS6281 in one PC?
If I can't open two instances of the same software used by the same cards in the same environment/operating system, so could use one of the cards with her software on a virtual machine solve this issue?
From what I understood this card can record 2 channels from different mux at the same time, right?
I need to know if this card have a dedicated chip for encoding/decoding or they use CPU or GPU, so I can understand which hardware I have to use for build the PC.
I found this model on Amazon: https://www.amazon.it/dp/B01B7TDIKQ/?co ... _lig_dp_it
What's the difference between the 6281 and the 6281SE?
mourn
Re: Is it possible to use more than a TBS6281 in one PC?
Postby mourn » Wed Dec 16, 2020 8:30 am
No one can help me?
mourn
Postby steven » Wed Dec 16, 2020 10:34 am
Hi Sir
You can use as many cards as you want , as we have no limit , as we know our customer using about 6x tuner cards works well
our tuner card just receive the orignal TS stream do not process it we do not have decoder and encoder inside.
for 6281 and 6281se the different is the PCI-E bridge .
Return to PCIe DVB-T2/T/C Dual Tuner Card TBS6281SE
