Unable load device driver under Windows Vista(x64)
Postby roshi » Sat Aug 10, 2019 11:41 pm
I have been using under the Windows Vista(x64).
download device driver from this page below. and installed.
https://www.tbsiptv.com/index.php?route ... .zip&id=10
device manager
- sound, video and game controller
- TBS 6281SE Dual DVBC BDA Tuners
However, this device has property error.
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
I tried reinstall the device driver manually.
and has been bcdedit /set TESTSIGNING OFF. but, not improved.
https://support.microsoft.com/en-us/hel ... in-windows
Is there anything I can do from here?
[EDIT] When I connect to a another Windows 10 installed PC, performed normally with the TBS6281SE DVB-C Windows 10 Driver.
roshi
Re: Unable load device driver under Windows Vista(x64)
Postby steven » Fri May 22, 2020 3:15 pm
recommend try with windows 7 or windows 10 which works well
thanks
Return to PCIe DVB-T2/T/C Dual Tuner Card TBS6281SE
