Windows 10 return from sleep problems
Postby AlunS » Thu Oct 12, 2017 4:24 am
When I have the Windows 10 driver (v 1.0.0.2) installed for this card, when my PC returns from sleep, Windows shows a black screen. It's not clear if it's just a blank screen that's the problem or if the PC simply hasn't returned from sleep though.
If I disable the device and remove the driver, everything works alright again.
I see the driver is now over 1 year old, is there a newer version available at all?
AlunS
Re: Windows 10 return from sleep problems
Postby steven » Fri Oct 13, 2017 11:21 am
Please have a try change the PCI-E slot and set BIOS disabled some options in the BIOS, such as intel AMT, idle power savings, turbo boost.
Postby AlunS » Fri Oct 13, 2017 8:29 pm
Hi Steven,
I eventually managed to solve it by changing the PCIE speed manually to PCIE 1.0 rather than AUTO. Neither PCIE 2.0 or PCIE 3.0 worked.
For reference it's an ASUS PRIME B250M-A motherboard, BIOS 0310, Intel Pentium G4600. No overclocking, or anything like that, just safe optimal BIOS settings.
I hope this is of some use.
Alun
AlunS
Postby AlunS » Fri Oct 13, 2017 11:58 pm
OK, I spoke too soon, if I resume the PC almost immediately after sleep, it's OK, but if I leave it any longer I still get a blank screen. After 2-3 minutes the PC then reboots.
AlunS
Postby steven » Sat Oct 14, 2017 8:19 pm
Which windows 10 version you are using ? and before sleep do you have closed the application ?
Return to PCIe DVB-T2/T/C Dual Tuner Card TBS6281SE
