pci-e x1 converter
pci-e x1 converter
Postby wie69 » Sat May 28, 2022 12:24 pm
hi...
i only have intel nuc pc with Thunderbolt 3 port...
is it possible to use this TBS6902 pci-express x1 ??? what converter should i use ??
wie69
Re: pci-e x1 converter
Postby steven » Mon May 30, 2022 6:20 pm
Hi Sir
Maybe you can try with USB tuner .like TBS5520se
Postby wie69 » Thu Jun 02, 2022 8:31 pm
hi steven
can you confirm that TBS5520SE can lock frequency 3870 H 51430 3/5 from satelit ABS-2 75E ???
thanks
wie69
Postby wie69 » Tue Jun 14, 2022 4:45 pm
hi steven..
i use akitio node, thunderbolt 3 to pcie converter box... it works ..
now. can you confirm that TBS6903X can handle symbol rate above 50K...
i need more confirm before i buy new card...
wie69
