Crazy scan now working.
Postby duane01098 » Sat Sep 17, 2016 6:36 pm
I downloaded the latest streamreader from crazycat and crazyscan is now working with the tbs6902 card. Thank you crazycat.
duane01098
Re: Crazy scan now working.
Postby member91040 » Wed Sep 21, 2016 8:03 pm
Could you please share the entire crazycat in zip or rar with included streamreader.
member91040
Postby duane01098 » Fri Sep 23, 2016 9:11 pm
Try this link https://sourceforge.net/projects/crazyscan/files/
This is difficult (inpossible for me ;had to go to library to connect) to reach on a dialup connection.
You will need Crazyscan.rar ,ReqLibs.rar and StreamReaderExEx-BDA.rar
I tried to upload ReqLibs.rar but kept timing out on dialup. Hopfully you can find it elsewhere .
Good Luck
CrazyScan(1).rar
(252.82 KiB) Downloaded 584 times
(707.7 KiB) Downloaded 838 times
I just found an easy to use link for all the crazyscan files.
http://sourceforge.mirrorservice.org/c/cr/crazyscan/
duane01098
Postby member91040 » Sat Sep 24, 2016 10:09 pm
Thank you so much for easy link, it all in one useful.
Any other blind scan software available please let us know, i have crazy scan and ebs pro.
member91040
