6910 SE Windows 10 Power State Failure issue
Postby fox07 » Mon Dec 23, 2024 4:35 am
Hello, I am using TBS 6910 SE card. I am using Windows 10 pro 22H2 version.
I am getting blue screen error after the computer is first started. "Power State Failure" error.
+The drivers are installed properly and it seems to be working properly in Windows device manager.
+I changed the mode to performance mode from power settings and disabled the saving mode for PCI express.
+I applied the following lines offered as a solution for this error on your site by preparing a file with .bat extension
Run regedit
REG ADD "HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MSIServer" /VE /T REG_SZ /F /D "Service"
net start msiserver
but I still get the "Power State Failure" error when the computer is first started.
Is there no solution to this problem? Will you release a new driver for this device?
fox07
Re: 6910 SE Windows 10 Power State Failure issue
Postby smile » Mon Dec 23, 2024 4:08 pm
Hello
please try diable the fast startup.
best regards
smile
Return to DVB-S2 Dual Tuner Dual CI PCIe Card TBS6910
