What PCI-E bridge is used in TBS6910?
Postby garry » Wed May 24, 2017 3:55 am
I plan to buy TBS6910 and TBS6908. Due to compatibility issues of old tuners (TBS6991 and TBS6984) with PCI-E Generations (https://www.tbsdtv.com/forum/viewtopic.php?f=69&t=9162), my question is:
what PCI-E bridge is used in TBS6910 and TBS6908? Is it also SAA7160?
Were these tuners tested on morden Supermicro and HP platforms? OS Linux.
Thanks.
garry
Re: What PCI-E bridge is used in TBS6910?
Postby steven » Wed May 24, 2017 10:26 am
Hi Garry
TBS6910 already use new PCI-E bridge which have not the compatiable issue like NXP7160 ,
so you do not need to worry about this
Return to DVB-S2 Dual Tuner Dual CI PCIe Card TBS6910
