Freezes with 6903x
Freezes with 6903x
Postby s0nnenschein » Fri Jul 14, 2023 1:29 pm
I have several problems with the 6903x under Windows (since I bought it).
Can anyone advices me why Crazyscan and EBSpro will sometimes freeze? In case no freeze tuning is very very slow. Using a 5927 on the same computer is very fast, on the other hand.
Spectrum scans in Crazyscan show wrong values. It looks like one transponder is repeated over the complete band. The pattern is similar. When I rescan, the same satellite always look different. Therefore, a spectrum looks random.
The calculated transponder bitrate is wrong in EBSpro. It will show the same value for all transponders, no matter if they are narrow or wide.
Any chance for a bug-free Windows driver? Because tuning under Linux works on the same machine.
Tried that in Windows 10 and reinstalled the PC to Windows 11.
s0nnenschein
Re: Freezes with 6903x
Postby smile » Fri Aug 11, 2023 5:52 pm
Hi sir
because the 6903X blindscan more complex algorithms. the official SDK does not optimize it, we have try opimize it by ourself. but it did not work out well.we are missing some critical documentation on bindscan.
Best Regards
smile
Postby s0nnenschein » Sun Aug 20, 2023 3:32 pm
Your answer is related to Blindscan.
I was talking about freezes even right after the start of Crazyscan.
s0nnenschein
