6904 with Windows Server 2019
Postby viperguy » Wed Jul 24, 2019 3:16 pm
I've just installed a TBS 6904 quad DVB S2 tuner into my Server 2019 Essentials test machine and absolutely cannot get any program or scanner to detect any channels...
The closest I can get is blind scan to report 16 channels or something but no other program will even report a signal lock. I know I have a working setup otherwise as I have a couple of Hauppauge cards in a Server 2012 Essentials machine that work beautifully so I know my infrastructure is working well.
Ive tried both the latest "windows" drives and the "windows 10 drivers" with no change in behaviour.
Could you please advise the next steps...
Regards.
viperguy
Re: 6904 with Windows Server 2019
Postby steven » Thu Jul 25, 2019 2:45 pm
For windows server version do you have installed the BDA patch ? like this :
https://www.tbsiptv.com/download/common/win2008_bda.zip
Postby crazycat » Sun Jul 28, 2019 6:24 am
viperguy Wrote:Ive tried both the latest "windows" drives and the "windows 10 drivers" with no change in behaviour
what dvb soft used ?
Postby viperguy » Sun Jul 28, 2019 7:42 pm
Well in an interesting turn I decided to swap cards with my hauppauge units in my production system and sure enough it works (and likewsie the hauppauge card does not work in the Server 2019 machine), so I now know the 6904 card is fully operational so I'm suspecting a BDA issue with server 2019, but I get an error trying to install the BDA patch on the Server 2019 system....
viperguy
Postby viperguy » Sun Jul 28, 2019 8:00 pm
Might have got it...
viperguy
Return to DVB-S2 Quad Tuner PCIe Card TBS6904
