Unicable compatible?
Postby drew » Mon Dec 11, 2017 2:53 pm
How to activat unicable-support on Linux (Debian stretch)?
on other cards i found the options mode=2 setting in modprobe.d/???.conf but tbsecp3 doesn't support this option..
drew
Re: Unicable compatible?
Postby steven » Tue Dec 12, 2017 10:01 am
For 6904 you just need direct use it not like the 6909 .
Postby drew » Wed Dec 13, 2017 6:48 am
hi steven,
what do you mean with direct use? ... splitter and 4 cables to each tuner?
at https://www.tbsdtv.com/products/tbs6904 ... -card.html is a statement unicable/onecable support
(this was the main reason for the buy of the card)
drew
Postby steven » Wed Dec 13, 2017 10:46 am
For 6909 because it has a multiswich inside so we need to set the mode for 6904 there is not multiswich direct connect to the tuner
so you just need connect 6904 one port to unicable port then you can use unicable .
Postby jokeroo » Tue Jun 26, 2018 9:04 pm
Im still having trouble to use unicable in my configuration, can someone cleary explain this how to connect or how to set driver to work wit it?
jokeroo
Postby steven » Wed Jul 04, 2018 11:17 am
Can you tell us that which tuner card and application you want to use with unicable ? and do you have your unicable infomration ?
Postby Monstamac » Fri Dec 18, 2020 12:00 am
Along side my other cards, Ive just got a 6904, do I need to use a splitter for unicable to all 4 ports or can I connect the unicable to just one port and if so, which one ??
thanks
Richard
Monstamac
Postby steven » Fri Dec 18, 2020 10:37 am
Hi Sir
For 6904 the 4 inputs all need signal input , and for unicable looks like need special splitter ,please care .
Return to DVB-S2 Quad Tuner PCIe Card TBS6904
