problem with diseqc switching
Postby dorijan » Tue Apr 25, 2017 4:39 pm
I am using tbs-linux-drivers_v170330.zip and I have problem with diseqc switching with mumudvb. I have other cards (TBS 6985) and same driver and diseqc seems to work ok.
However when I try to scan with scan-s2, it works, so maybe it is something about implementation or timings on TBS6904.
There are full logs of scanning here:
https://github.com/braice/MuMuDVB/issues/169
Please help.
Thank you
dorijan
Re: problem with diseqc switching
Postby steven » Thu May 18, 2017 2:34 pm
can you have a try with this driver ? :
#wget http://www.tbsdtv.com/download/document ... st.tar.bz2
#tar jxvf media_build-latest.tar.bz2
#cd media_build
#./install.sh
#reboot
Return to DVB-S2 Quad Tuner PCIe Card TBS6904
