[ Moderator Control Panel ]
by nightshadow36 » Sun May 29, 2016 8:24 am
Hello.
Here is my setup so i guess i would need mode 2?
quattro LnB / Multiswitch / 6909. Tuner 1/2 is norwegian sat - Tuner 3/4 is english sat.
If i use mode 0 tuner 1/2 works but not 3/4
If i use mode 2 nothing works.
- Attachments
nightshadow36
by steven » Tue May 31, 2016 10:03 am
Hi nightshadow36
when using mode 2,all 8 tuner will using the same satellite. Please have a try with mode 0,
every two tuner using the same satellite and same signal type such as both are VL or VH.
make sure that like this.
by stilmant » Tue May 31, 2016 5:46 pm
Just by curiosity, I've never yet stumbleupon that config mode 0 or any value. Where this is documented? is it specific to 6909 ? Thanks.
stilmant
by stilmant » Thu Jun 02, 2016 8:54 pm
Thanks, I don't own that card, so it is maybe why, but that documentation link seems not provided in the download section package right?
How did you get to that documentation? (Asking this to see if I'm not missing some information sources)
stilmant
by nightshadow36 » Sun Jun 05, 2016 10:46 am
You go to the downloads page and select the card you have.
Then open the driver page, it has the driver and the quick start guide.
Maybe they only have a guide for octa tuner?
http://www.tbsdtv.com/download/
nightshadow36
