Brand new TBS6909X V2 adapters not detected
Postby bobben » Wed Apr 24, 2024 12:56 am
I have a problem with a brand new TBS6909X V2 received a few days ago.
Tested for the first time today and get the same problem in both fedora38 and ubuntu 22.04.3 LTS. My older TBS6909X V2 works. Last tests is done in ubuntu 22.04.3 with only the new card in the computer.
Is this kind of errors I get in dmesg log something that is known or is the card DOA?
dmesg | grep 'tbsecp3\|stid135\|STiD\|TBSECP3'
[    3.465834] TBSECP3 driver 0000:02:00.0: enabling device (0000 -> 0002)
[    3.466753] TBSECP3 driver 0000:02:00.0: TurboSight TBS 6909x
[    3.487429] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[    3.605292] TBSECP3 driver 0000:02:00.0: adap=000000004d1f8026 dvb_adap=000000004e9de327 adap=0 MAC address 00:22:ab:90:04:90
[    3.956018] stid135_attach:2294 ATTACH NEW nr=0 rf_in=0 base=00000000fa083a08 count=1 i2c_addr=0x68 i2c=i2c-3
[    3.956032] i2c i2c-3: STiD135-LLA_REL_1.4.0-December_2018
[    4.933946] TBSECP3 driver 0000:02:00.0: i2c nack (7)
[    4.933985] TBSECP3 driver 0000:02:00.0: i2c nack (7)
[    4.933995] stid135_probe:331 fe_stid135_init error 13 !
[    4.933996] stid135_attach:2314 No demod found at adr 68 on i2c-3
[    4.934013] TBSECP3 driver 0000:02:00.0: TBSECP3 frontend 0 attach failed
[    4.934024] TBSECP3 driver 0000:02:00.0: frontend attach failed
[    4.934143] tbsecp3_adapters_attach:98 adapter[0]=000000004d1f8026 tbs_nr=0 dvb_nr=0 q=64
[    4.934147] TBSECP3 driver 0000:02:00.0: adapter0 attach failed
[    4.934162] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[    5.053121] TBSECP3 driver 0000:02:00.0: i2c nack (7)
[    5.053156] TBSECP3 driver 0000:02:00.0: i2c nack (7)
[    5.053166] TBSECP3 driver 0000:02:00.0: error reading MAC address for adapter 1
[    5.053186] stid135_attach:2294 ATTACH NEW nr=1 rf_in=1 base=00000000e5d4aacf count=1 i2c_addr=0x68 i2c=i2c-3
[    5.053189] i2c i2c-3: STiD135-LLA_REL_1.4.0-December_2018
[    5.053294] TBSECP3 driver 0000:02:00.0: i2c nack (7)
[    5.814750] TBSECP3 driver 0000:02:00.0: i2c nack (7)
[    5.814767] TBSECP3 driver 0000:02:00.0: i2c nack (7)
[    5.814768] stid135_probe:331 fe_stid135_init error 13 !
[    5.814770] stid135_attach:2314 No demod found at adr 68 on i2c-3
[    5.814784] TBSECP3 driver 0000:02:00.0: TBSECP3 frontend 1 attach failed
[    5.814786] TBSECP3 driver 0000:02:00.0: frontend attach failed
[    5.814894] tbsecp3_adapters_attach:98 adapter[1]=000000003628cc46 tbs_nr=1 dvb_nr=0 q=64
[    5.814897] TBSECP3 driver 0000:02:00.0: adapter1 attach failed
[    5.814898] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[    5.932747] TBSECP3 driver 0000:02:00.0: i2c nack (7)
[    5.932824] TBSECP3 driver 0000:02:00.0: i2c nack (7)
[    5.932827] TBSECP3 driver 0000:02:00.0: error reading MAC address for adapter 2
[    5.932843] stid135_attach:2294 ATTACH NEW nr=2 rf_in=2 base=000000008f1add25 count=1 i2c_addr=0x68 i2c=i2c-3
[    5.932846] i2c i2c-3: STiD135-LLA_REL_1.4.0-December_2018
[    5.933008] TBSECP3 driver 0000:02:00.0: i2c nack (7)
[    6.686402] TBSECP3 driver 0000:02:00.0: i2c nack (7)
[    6.686420] TBSECP3 driver 0000:02:00.0: i2c nack (7)
[    6.686423] stid135_probe:331 fe_stid135_init error 13 !
[    6.686425] stid135_attach:2314 No demod found at adr 68 on i2c-3
[    6.686444] TBSECP3 driver 0000:02:00.0: TBSECP3 frontend 2 attach failed
[    6.686446] TBSECP3 driver 0000:02:00.0: frontend attach failed
[    6.686678] tbsecp3_adapters_attach:98 adapter[2]=000000002081b2dc tbs_nr=2 dvb_nr=0 q=64
[    6.686684] TBSECP3 driver 0000:02:00.0: adapter2 attach failed
[    6.686687] dvbdev: DVB: registering new adapter (TBSECP3 DVB Adapter)
[    6.804755] TBSECP3 driver 0000:02:00.0: i2c nack (7)
[    6.804824] TBSECP3 driver 0000:02:00.0: i2c nack (7)
[    6.804827] TBSECP3 driver 0000:02:00.0: error reading MAC address for adapter 3
[    6.804846] stid135_attach:2294 ATTACH NEW nr=3 rf_in=3 base=00000000777ecd23 count=1 i2c_addr=0x68 i2c=i2c-3
[    6.804850] i2c i2c-3: STiD135-LLA_REL_1.4.0-December_2018
[    6.805009] TBSECP3 driver 0000:02:00.0: i2c nack (7)
[    7.558189] TBSECP3 driver 0000:02:00.0: i2c nack (7)
[    7.558207] TBSECP3 driver 0000:02:00.0: i2c nack (7)
[    7.558209] stid135_probe:331 fe_stid135_init error 13 !
[    7.558210] stid135_attach:2314 No demod found at adr 68 on i2c-3
[    7.558225] TBSECP3 driver 0000:02:00.0: TBSECP3 frontend 3 attach failed
[    7.558227] TBSECP3 driver 0000:02:00.0: frontend attach failed
[    7.558406] tbsecp3_adapters_attach:98 adapter[3]=000000001689972f tbs_nr=3 dvb_nr=0 q=64
[    7.558410] TBSECP3 driver 0000:02:00.0: adapter3 attach failed
+ similar errors for the other remaining adapters on the tbs6909x card....
lspci -vvnn
02:00.0 Multimedia controller [0480]: TBS Technologies DVB Tuner PCIe Card [544d:6178]
        Subsystem: Device [6909:0010]
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
        Interrupt: pin A routed to IRQ 141
        Region 0: Memory at b1100000 (32-bit, non-prefetchable) [size=256K]
        Capabilities: [70] MSI: Enable+ Count=1/1 Maskable- 64bit+
                Address: 00000000fee004d8  Data: 0000
        Capabilities: [90] Express (v1) Endpoint, MSI 00
                        ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 0.000W
                DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
                DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
                LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s, Exit Latency L0s unlimited
                        ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
                LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
                LnkSta: Speed 2.5GT/s (ok), Width x1 (ok)
                        TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
        Capabilities: [100 v1] Device Serial Number 00-00-00-00-00-00-00-00
        Kernel driver in use: TBSECP3 driver
        Kernel modules: tbsecp3
bobben
Re: Brand new TBS6909X V2 adapters not detected
Postby crazycat » Wed Apr 24, 2024 7:36 am
look like hw issues, no answer i2c from eeprom, demod
Postby bobben » Wed Apr 24, 2024 9:32 pm
I changed BIOS pcie generation setting from "auto" to "gen1" and now the card is detected and so far it works ok.
bobben
