Best settings in tvheadend for TBS6909x
Postby jku131 » Fri Feb 26, 2021 4:54 pm
Hello, I'm using tbs6909x card in tvheadend in mode 0 with quattro lnb.
Can somebody tell me what are best settings for tvheadend to get fast channel switching and good stability?
I see there are options like "Full DiseqC:", "Tune before DiseqC:", "Higher LNB voltage:", "Status period (ms):", "Input buffer (bytes):", "Skip initial bytes:".
How should I set this to get best stability and fast channel switching?
Do I need to enable "Full DiseqC:" when I have quattro lnb?
jku131
Re: Best settings in tvheadend for TBS6909x
Postby smile » Mon Mar 01, 2021 10:36 am
You can try set the "status period" to 3000 , "input buffer (bytes)" set to 10 times of dafult value .
Best Regards
smile
Postby jku131 » Thu Mar 04, 2021 6:27 pm
Hi, thanks for response.
I'm currently using "Status period (ms):" 5000 and "Input buffer (bytes):" 188000, what are default values?
also what about "Skip initial bytes:", "Higher LNB voltage:", "Full DiseqC:", "Tune before DiseqC:" how should i set it to get best stability and fast channel switching?
jku131
Postby crazycat » Sat Mar 06, 2021 4:35 am
Use default serrings
