TBS6909-X V1 vs TBS6909-X V2 - what difference?
Postby mustang01 » Mon Feb 08, 2021 12:38 am
Hello, I have a problem with the TBS 6909-X V1. I have had this card for several years and replaced it with another one under the warranty.
I have glitches and picture errors when watching TV or recording. I replaced the antenna installation, but it did not help. I am using VDR software and have updated it with the drivers to the latest version but that didn't help. I spotted a noisy computer environment and gave up. I started my topic about the signal problem here -> viewtopic.php?f=176&t=25324.
Replacing the card on the guarantee helped the most. I wanted to ask if the new revision of the V2 penalty improved my signal problems or was it only slightly rebuilt in terms of available electronic components?
Will it help me to change the converter from quattro to quad and buy a card with a smaller number of heads, eg TBS6904? In my home I have an antenna installation with a twin converter and OCTAGON SF8008 receiver and I do not have such problems there.
mustang01
Re: TBS6909-X V1 vs TBS6909-X V2 - what difference?
Postby mustang01 » Fri Feb 12, 2021 2:18 am
I read this topic -> https://github.com/tbsdtv/linux_media/issues/179 .
it says: "P.S. Your V2 prototype similar to V1.x, but same pci id and some fixes in power circuit. Released V2 have different pci id and require VGLNA init in driver (with old driver you just not have signal)."
mustang01
