TBS6909 connections
TBS6909 connections
Postby hsmptg » Mon May 13, 2019 6:40 pm
I need to connect a TBS6909 to a Sat multiswitch 5/8.
I already have connected to that multiswitch a SAT receiver and a TBS6982 (both working OK).
Can I use TBS6909 in Mode 1 or Mode 2 with the following cable configuration?
My initial attempts were not very successful since I always have a FAIL during the scan process! :(
Any help please?
Regards
hsmptg
Re: TBS6909 connections
Postby crazycat » Tue May 14, 2019 1:10 am
mode 1 - each tuner pairs must be tuned to same pol/band.
for your case better use default mode 0 and you can tune any transponder on each tuner.
P.S. low SR transponeder usual not locked (<10000 Ks).
Postby hsmptg » Tue May 14, 2019 6:37 am
Thanks @crazycat
I will try that!
To change to mode 0, I just have to edit the /etc/modprobe.d/mxl58x.conf file with "options mxl58x mode=0", right?
It is enough or I need then to compile the driver again?
Regards
hsmptg
Postby crazycat » Tue May 14, 2019 8:47 am
just edit modprobe config (comment or delete mxl58x options, default mode=0)
