TBS 6909 ubuntu 14.04
Postby domini » Tue Nov 07, 2017 10:17 pm
Hello TBS support team, first of all I would like to say that I need your help a lot, I have a tbs6985 and a tbs6909, I'm using ubuntu server 14.04 (Linux IPTVHEADEND 4.4.0-31-generic #50~14.04.1-Ubuntu SMP Wed Jul 13 01:07:32 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux) and I already tried to install using open source drivers and tbs drivers. when I installed using open source the system detected the board with the command dmesg | grep fron, but after restarting the system detected no more! I need to know in which linux distribution the TBS cards work perfectly, because I am building headend . If it is possible and necessary, I give you access to the computer so that you can analyze what can be done. I also have a moi that was even the first product I bought from you and need to reinstall firmware. Thank you and I await your response. I know that you (Bob, Steven & James) are serious people and will help me. thanks
domini
Re: TBS 6909 ubuntu 14.04
Postby steven » Wed Nov 08, 2017 10:54 am
When you reboot your PC check whether you have update the kernel ,the system default setting the kernel will auto update ,
after kernel update you need to reinstall the driver again as the file already changed .
You can using these command to disable the kernel update :
open the file /etc/apt/apt.conf.d/10periodic and change
APT::Periodic::Update-Package-Lists "1";
to
APT::Periodic::Update-Package-Lists "0";
#apt-mark hold linux-image-generic linux-headers-generic
Postby domini » Wed Nov 15, 2017 8:04 am
Hello Steven ! how are you man ? i hope good ! i had 2 cards to install. i got success installing tbs 6985 on ubuntu 14.04. but my tbs 6909 work after using this tutorial (https://github.com/tbsdtv/linux_media/wiki) ... the problem came after reboot computer... when i used dmesg | grep fron i get no message. then i use (tar jxvf tbs-tuner-firmwares_v1.0.tar.bz2 -C /lib/firmware/) and reboot again then i get ;
root@IPTV2:/home/tom# dmesg | grep fron
[ 19.083670] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 0 frontend 0 (MXL5XX)...
[ 19.204814] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 1 frontend 0 (MXL5XX)...
[ 19.321003] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 2 frontend 0 (MXL5XX)...
[ 19.436438] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 3 frontend 0 (MXL5XX)...
[ 19.556478] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 4 frontend 0 (MXL5XX)...
[ 19.636448] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 5 frontend 0 (MXL5XX)...
[ 19.755741] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 6 frontend 0 (MXL5XX)...
[ 19.861136] TBSECP3 driver 0000:03:00.0: DVB: registering adapter 7 frontend 0 (MXL5XX)...
until e reboot again and stop working again
what should i do bro ? i already used the commands you told me above!
domini
Postby steven » Wed Nov 15, 2017 10:56 am
#wget http://www.tbsdtv.com/download/document ... 16.tar.bz2
#tar jxvf media_build-2017-1016.tar.bz2
#cd media_build
#./install.sh
#reboot
Postby zsozso » Mon Dec 04, 2017 6:26 pm
and new driver solved your kernel problem?
My Ubuntu kernel is 14.3
Dec 4 11:05:58 lajhar kernel: [ 8093.536077] i2c read error 1
Dec 4 11:05:58 lajhar kernel: [ 8093.536078] i2c read error 2
Dec 4 11:05:59 lajhar kernel: [ 8094.560077] TBSECP3 driver 0000:30:00.0: i2c xfer timeout
Dec 4 11:05:59 lajhar kernel: [ 8094.560080] i2c write error
Dec 4 11:06:00 lajhar kernel: [ 8095.584075] TBSECP3 driver 0000:30:00.0: i2c xfer timeout
Dec 4 11:06:00 lajhar kernel: [ 8095.584079] i2c write error
Dec 4 11:05:56 lajhar tvheadend[513]: message repeated 3 times: [ linuxdvb: TurboSight TBS 6909 DVB-S/S2 #2 : DVB-S #0 - poll TIMEOUT]
Dec 4 11:06:01 lajhar kernel: [ 8096.608077] TBSECP3 driver 0000:30:00.0: i2c xfer timeout
Dec 4 11:06:01 lajhar kernel: [ 8096.608083] i2c read error 1
Dec 4 11:06:01 lajhar kernel: [ 8096.608084] i2c read error 2
Dec 4 11:06:02 lajhar kernel: [ 8097.632028] TBSECP3 driver 0000:30:00.0: i2c xfer timeout
Dec 4 11:06:02 lajhar kernel: [ 8097.632034] i2c write error
zsozso
Postby steven » Tue Dec 05, 2017 4:09 pm
Hi Zsozso
Please have a try change the PCI-E slot and connect the extra power for your 6909 .
check whether is ok
Postby bestazy » Fri Jan 26, 2018 6:21 pm
Hello, I bought a TBS5922SE Card, I would like to use it in Linux, I need a help installing this card in Ubuntu 14.04 64 Bits? I tried, but I can not install this card, if possible help me.
Thank you
bestazy
Postby steven » Mon Jan 29, 2018 9:50 am
Hi bestazy
Try with this package :
#wget http://www.tbsdtv.com/download/document/linux/media_build-2017-1016.tar.bz2
#cd media_build
#./install.sh
#reboot
Postby Formaster » Fri Feb 01, 2019 5:46 am
Hi steven,
I really need some help. I bought some TBS 6909 cards and i become no signal in Unicable mode in Astra. Of course the config file added with mode2, but the problem still stay. I have no idea, maybe driver issue, while in the same server i have already used TBS 6904 card without any problem, just not as Unicable. I really glad if somebody has a good idea, or can solve the problem via ssh or astra login. Regards, Formaster
Formaster
Postby steven » Thu Feb 14, 2019 10:52 am
hi
can you have a try test the unicable with tvheadend ? check whether is ok
