Problems with V/H and V/L
Postby SPiKeGoD » Wed Oct 04, 2017 3:07 am
I have a tbs2951 and two tbs6909 and an only satellite antenna
I have sd channels in a tbs6909 and the hd channels in the other one, all the frecuencies are Vertical Low, so I have two cables from a splitter for the input 0 of both TBS6909
But i want to add a vertical high SD frecuency. Is it possible? (only one antenna with an only lnb)
I have tried to add another cable from the splitter to the input 1 of the tbs6909 (two cable 1 in input 0 and another one in input 1) that i use for sd channels, and the vertical high frecuency works but the vertical low frecuencies do not work... :(
Can i do it anything ?
Thanks a lot in advance
PD: I use tvheadend
SPiKeGoD
Re: Problems with V/H and V/L
Postby steven » Mon Oct 09, 2017 10:39 am
Hi SPiKeGoD
With one cable you can not use Low band and high band at the same time ,as high band need 22k signal low band do not need it
only one cable can not do this , you can have a try with quad LNB .
