TBSECP3 driver 0000:02:00.0: i2c xfer timeout
Postby paule3d » Sat May 20, 2017 12:18 am
Hi. I have TBS 6909.
After 2-3 days, it stops working and dmesg is full of these messages
Any help please?
May 14 17:06:35 encoder2 kernel: [295818.704158] i2c read error 1
May 14 17:06:35 encoder2 kernel: [295818.704161] i2c read error 2
May 14 17:06:36 encoder2 kernel: [295819.703976] TBSECP3 driver 0000:02:00.0: i2c xfer timeout
May 14 17:06:36 encoder2 kernel: [295819.703982] i2c write error
May 14 17:06:37 encoder2 kernel: [295820.703995] TBSECP3 driver 0000:02:00.0: i2c xfer timeout
May 14 17:06:37 encoder2 kernel: [295820.704000] i2c write error
May 14 17:06:38 encoder2 kernel: [295821.703982] TBSECP3 driver 0000:02:00.0: i2c xfer timeout
May 14 17:06:38 encoder2 kernel: [295821.703989] i2c read error 1
May 14 17:06:38 encoder2 kernel: [295821.703991] i2c read error 2
May 14 17:06:39 encoder2 kernel: [295822.703995] TBSECP3 driver 0000:02:00.0: i2c xfer timeout
May 14 17:06:39 encoder2 kernel: [295822.704007] i2c write error
May 14 17:06:40 encoder2 kernel: [295823.703983] TBSECP3 driver 0000:02:00.0: i2c xfer timeout
May 14 17:06:40 encoder2 kernel: [295823.703990] i2c write error
May 14 17:06:41 encoder2 kernel: [295824.703937] TBSECP3 driver 0000:02:00.0: i2c xfer timeout
May 14 17:06:41 encoder2 kernel: [295824.703944] i2c read error 1
May 14 17:06:41 encoder2 kernel: [295824.703945] i2c read error 2
May 14 17:06:42 encoder2 kernel: [295825.703957] TBSECP3 driver 0000:02:00.0: i2c xfer timeout
May 14 17:06:42 encoder2 kernel: [295825.703967] i2c write error
May 14 17:06:43 encoder2 kernel: [295826.703995] TBSECP3 driver 0000:02:00.0: i2c xfer timeout
May 14 17:06:43 encoder2 kernel: [295826.704006] i2c write error
May 14 17:06:44 encoder2 kernel: [295827.703929] TBSECP3 driver 0000:02:00.0: i2c xfer timeout
May 14 17:06:44 encoder2 kernel: [295827.703939] i2c read error 1
May 14 17:06:44 encoder2 kernel: [295827.703942] i2c read error 2
May 14 17:06:45 encoder2 kernel: [295828.703933] TBSECP3 driver 0000:02:00.0: i2c xfer timeout
May 14 17:06:45 encoder2 kernel: [295828.703943] i2c write error
May 14 17:06:46 encoder2 kernel: [295829.703926] TBSECP3 driver 0000:02:00.0: i2c xfer timeout
May 14 17:06:46 encoder2 kernel: [295829.703931] i2c write error
May 14 17:06:47 encoder2 kernel: [295830.703961] TBSECP3 driver 0000:02:00.0: i2c xfer timeout
May 14 17:06:47 encoder2 kernel: [295830.703977] i2c read error 1
paule3d
Re: TBSECP3 driver 0000:02:00.0: i2c xfer timeout
Postby crazycat » Sat May 20, 2017 4:38 am
try disable MSI interrupt
options tbsecp3 enable_msi=0
Postby paule3d » Sat May 20, 2017 5:16 am
Where to put this?
I've seen 2 different instructions about editing files in modprobe or somewhere similar.
/etc/modprobe.d/tbs.conf
and
/etc/modprobe.d/mxl5xx.conf
paule3d
Postby steven » Sat May 20, 2017 8:14 am
If you are using open source driver use this
/etc/modprobe.d/dvb.conf
Postby paule3d » Tue May 23, 2017 12:46 pm
now I have 3 files in modprobe - do I put all options in a single file? How do I know if they are working or not? THanks
tbs.conf
mxl5xx.conf
dvb.conf
paule3d
Postby steven » Wed May 24, 2017 11:38 am
if you are using open source driver you do not need the
tbs.conf file any more you can remove it
