Modules decrypting
Modules decrypting
Postby Burns » Tue Mar 21, 2017 12:52 am
I'm wondering if it's actually possible to decrypt channels coming out from TBS6909 using the module of another TBS PCI card.
Or are we limited to only the signals coming out from the module PCI card?
In the case we can't decrpyt, then TBS6909 will be only useful for FTA channels?
Burns
Re: Modules decrypting
Postby crazycat » Tue Mar 21, 2017 4:10 am
Use cardreader and soft descrambler.
Postby Burns » Tue Mar 21, 2017 6:53 am
crazycat Wrote:Use cardreader and soft descrambler.
Not what i'm looking for. I just want an answer to my question to know what i'm gonna do
Burns
Postby rubdos » Mon Jul 31, 2017 11:24 pm
It actually is the answer you're looking for. There's no other way currently than to do that.
rubdos
