TBS 6909 linux install / reinstall problem
Postby paule3d » Thu Mar 02, 2017 4:07 am
I had this working a few months ago.
THen I havent used it.
Today the card drivers are not loaded. /dev/dvb/ does not exist.
lspci shows 6909
I try to reinstall following instructions http://www.tbsiptv.com/download/tbs6909 ... _guide.pdf
on step "make", this is output (I even tried sudo make):
make[2]: Entering directory '/usr/src/linux-headers-4.4.0-45-generic'
CC [M] /home/user/tbsdriver/media_build/v4l/cxd2820r_core.o
/home/user/tbsdriver/media_build/v4l/cxd2820r_core.c: In function 'cxd2820r_gpio_direction_output':
/home/user/tbsdriver/media_build/v4l/cxd2820r_core.c:447:31: error: implicit declaration of function 'gpiochip_get_data' [-Werror=implicit-function-declaration]
struct cxd2820r_priv *priv = gpiochip_get_data(chip);
/home/user/tbsdriver/media_build/v4l/cxd2820r_core.c:447:31: warning: initialization makes pointer from integer without a cast [-Wint-conversion]
/home/user/tbsdriver/media_build/v4l/cxd2820r_core.c: In function 'cxd2820r_gpio_set':
/home/user/tbsdriver/media_build/v4l/cxd2820r_core.c:461:31: warning: initialization makes pointer from integer without a cast [-Wint-conversion]
/home/user/tbsdriver/media_build/v4l/cxd2820r_core.c: In function 'cxd2820r_gpio_get':
/home/user/tbsdriver/media_build/v4l/cxd2820r_core.c:477:31: warning: initialization makes pointer from integer without a cast [-Wint-conversion]
/home/user/tbsdriver/media_build/v4l/cxd2820r_core.c: In function 'cxd2820r_probe':
/home/user/tbsdriver/media_build/v4l/cxd2820r_core.c:685:9: error: implicit declaration of function 'gpiochip_add_data' [-Werror=implicit-function-declaration]
ret = gpiochip_add_data(&priv->gpio_chip, priv);
scripts/Makefile.build:258: recipe for target '/home/user/tbsdriver/media_build/v4l/cxd2820r_core.o' failed
make[3]: *** [/home/user/tbsdriver/media_build/v4l/cxd2820r_core.o] Error 1
Makefile:1403: recipe for target '_module_/home/user/tbsdriver/media_build/v4l' failed
make[2]: *** [_module_/home/user/tbsdriver/media_build/v4l] Error 2
make[2]: Leaving directory '/usr/src/linux-headers-4.4.0-45-generic'
make[1]: Leaving directory '/home/user/tbsdriver/media_build/v4l'
make: *** [all] Error 2
any help please?
paule3d
Re: TBS 6909 linux install / reinstall problem
Postby steven » Thu Mar 02, 2017 3:09 pm
Please contact our support and you can set a SSH remote we will have a check with this
and you can have a try with this package too :
#wget http://www.tbsdtv.com/download/document/linux/media_build-0119.tar.bz2
#tar jxvf media_build-0119.tar.bz2
#cd media_build
#./install.sh
#reboot
Postby xiaocao » Thu Mar 02, 2017 3:18 pm
1.Firmware
wget http://www.tbsdtv.com/download/document ... .0.tar.bz2
tar jxvf tbs-tuner-firmwares_v1.0.tar.bz2 -C /lib/firmware/
2.Downloading and building
cd media_build
make dir DIR=../media
make distclean
make -j4
make install
reboot
xiaocao
Postby paule3d » Thu Mar 02, 2017 8:01 pm
Hello guys. I think I have got it working before I saw your reply -
I don't know what fixed it as I did a lot of things:
sudo apt-get update
sudo apt-get upgrade
Then I see somebody else having similar problems installing pci card on linux and he says this command fixed things for him, so I tried this:
sudo apt-get install linux-headers-`uname -r` build-essential subversion mercurial openssl gettext libssl-dev screen libv4l-dev
full driver install
reboot
Now I have 8 adapters in /dev/dvb
Hopefully this will help somebody else who has same problem and find this page on google.
Regards
paule3d
Postby ReidHao » Sat Dec 08, 2018 2:19 am
Hi....After a clean reinstall of my Ubuntu the other week I am having trouble installing the TBS6981 drivers.
I have run through the instructions many times in the past (usually after upgrading the kernel) without any issue but this time it doesn't work. The strange thing is that it worked last week and there have been no changes to the kernel since then.
ReidHao
Postby steven » Mon Dec 10, 2018 9:56 am
ReidHao Wrote:Hi....After a clean reinstall of my Ubuntu the other week I am having trouble installing the TBS6981 drivers.
which kernel you are using ,as for TBS6981 the driver already merged to the kernel .
