Anyone work with mumudvb
Postby krmlk » Sat Dec 17, 2016 5:43 pm
This my second MOI Pro this time I preferred 6909. It was a really wrong decision because for a few days I am trying to use my system stabile. mumudvb doesn't work with the message "FE_HAS_SIGNAL : found something above the noise level". DVBBLast has got disconnect problems. After 1-24 hours every stream disconnect without any reason.
So I would like to ask is there anybody work mumudvb with 6909 without problem?
krmlk
Re: Anyone work with mumudvb
Postby steven » Mon Dec 19, 2016 2:52 pm
You are using 6909 with MOIPro or MOIPro-AMD ?
and for your mumudvb issue do you have more detail information ? such as your mumudvb config and the transponder information ?
And you can send email to our support#tbsdtv.com to get fast reply.
Postby krmlk » Sun Dec 25, 2016 3:19 am
6909 with MOI Pro AMD
it doesnt matter which satellite or LNB or Transporder. I am getting always this error. I can work with astra cesbo, tvheadend and dvblast. Only mumudvb doesnt work
here is the sample config:
card=15
multicast=0
multicast_ipv4=0
multicast_ipv6=0
port_http=4265
unicast=1
freq=12641
pol=h
srate=30000
dvr_buffer_size=7
ip_http=0.0.0.0
autoconfiguration=full
or
card=14
multicast=0
multicast_ipv4=0
multicast_ipv6=0
port_http=4252
unicast=1
freq=12265
pol=v
srate=27500
dvr_buffer_size=12
ip_http=0.0.0.0
new_channel
name=Power Turk HD
service_id=14603
pids=3403 3503 261 3403
edit: after a many tries I realized that only first dvb card (first 6909) works with mumudvb. The other programs also have some problems with second card. Could that this card doesn't work? I can see te device list, however
krmlk
