Problem with using 6909 on C band
Postby limiteddi » Sat Nov 12, 2016 12:23 am
I use C band with same V polarity. When I put in passive 2/4 switch and connect 4 cables to TBS6909 it was working fine. But when I use TBS multiswitch and connect to card I can't understand the logic: some transponders work and some do not, some adapters work on some transponders and some not. I have tried everything but it doesnt seem to work. Any suggestions?
limiteddi
Re: Adapter 7 works but 6 doesnt?
Postby limiteddi » Sun Nov 13, 2016 8:22 am
Also i found some information that for C band is only need input to 0 and 2? Also, which input would i use on your switch than for V on C band? Verical-Low?
limiteddi
Re: Problem with using 6909 on C band
Postby steven » Fri Dec 16, 2016 2:29 pm
If you C band LNB is single band 5150 then you only need to put input 0 and input 2,
and for 6909 please use the latest open source driver which we fixed when use multiswich more than one satellite input.
https://github.com/tbsdtv/linux_media/c ... f1b9d2c904
Postby spacedvb » Fri Jun 09, 2017 3:40 am
i never see such dvbs2 product like this, even when 8psk Turbocode BCM from Skywalker came out , support and fix always was there,, but this 6909 I need my money back our exchange to TBS6908 . never buy this pcs of shit aging.
spacedvb
