Extra power
Extra power
Postby pieman » Sat Oct 15, 2016 1:19 am
I am wondering what giving the card extra power from the molex connector will actually do?
As at present I seem to be able to receive 30 concurrent streams from it.
What is the advantage? Why is it their?
pieman
Re: Extra power
Postby steven » Mon Oct 24, 2016 2:34 pm
Hi pieman
usually do not need to use the extra power ,in some case such as connect a big motor the power from PCI-E slot not enough then
you can use the extra power.
Kind regards
