Suitable DC block?
Suitable DC block?
Postby paule3d » Tue Sep 27, 2016 9:34 pm
Hello. I have just purchased a TBS6909 and I am excited to start using it soon.
If I have 2 cables from LNB, and one will be H and one will be for V, I would need to use a splitter, but I read that splitter is dangerous for the card due to voltage to the LNB for switching.
Please can somebody tell me if this is a suitable DC block?
http://www.aerialsat.com/prod/2-x-f-thr ... dcb01.html
Frequency only says 950-2050MHz but I think Sky / satellite TV goes up 20,000 Mhz etc?
Thank you
paule3d
Re: Suitable DC block?
Postby steven » Mon Oct 10, 2016 3:29 pm
If the DC block works well this should be ok ,but the best is using a multiswich : )
Kind regards
