6909 and windows
6909 and windows
Postby mikeh » Thu Sep 22, 2016 6:14 pm
I have installed the card and driver into windows 10.
Install card, connect power cable and connect 4 sat leads from quad lnb.
When I use Mediaportal to scan Astra at 28.2E it shows no signal level (under scan progress) and only finds anything at all on 5 transponders...
I used a 6985 before and have not seen these problems - is there anything I should do differently?
Any help appreciated.
mikeh
