UDP and disconnect problem
Postby krmlk » Sun Apr 03, 2016 7:44 am
Dear all
I can get the stream via dvblast and rtp://@239.255.13.7:9981
I have 2 problems: first of all my stream disconnecting every 3-5 minute and the other one is I can't select UDP. If I select this I can 'tstart a stream in transcode server.
edit: if I select only one stream everything works great, after 2 stream disconnecting the stream every 5-10 minutes. AAfter 5-6 Streams video is defecting and disconnect appromixetly every 1 minutes
krmlk
Return to MOI Pro - AMD
