scan failed error
scan failed error
Postby krmlk » Fri Apr 01, 2016 1:38 am
Dear all,
I connected two different Satellites to box. Problem is I don't know exactly which satellites. One should be Astra 19E or Hotbird 13E. If select from VDR this satellites I see always scan failed error. I am pretty new for this device. I didn't select tvheadend, either.
krmlk
Re: scan failed error
Postby steven » Fri Apr 01, 2016 5:48 pm
Hi krmlk
You can using dvblast to scan the transponder to check the signal which satellite is ,or you can set a remote connection
to our support we will help you about this.s
Return to MOI Pro - AMD
Users browsing this forum: Bing [Bot] and 3 guests
