MOI PRO AMD Astra Cesbo
Postby DCM2016 » Sun Mar 20, 2016 3:34 am
I have since 2 days the Moi Pro AMD. I have a satellite antenna 19.2 °.
In Moi Pro Amd 4 x TBS-6910 are installed.
I VDR and Dvblast tried but without success.
I simply do not come next. I get no sender.
The antenna is 100% all ok. Satellite receiver shows all ok and the transmitter also.
I've been using Putty tried ASTRA CESBO to Insterlieren. That did not work either.
I would be very happy if you would help me. thank you
DCM2016
Re: MOI PRO AMD Astra Cesbo
Postby even » Fri Mar 25, 2016 6:14 pm
Hi DCM2016
Can you tell us the parameters you used to scan ?
And you can set a remote connection and send your remote connection information to our support we will help you
have a remote check
Kind Regard
even
Site Admin
Return to MOI Pro - AMD
