Stuck at update
Stuck at update
Postby juliux » Fri Jan 29, 2016 8:39 am
Steven , why is soo dificult to update this flawless , downloaded web update and i get stuck at 9 %.
what's happening now?
juliux
Re: Stuck at update
Postby steven » Mon Mar 07, 2016 11:43 am
hi juliux
Do you have unpack the zip file ? and which version you are using before update ?
If you still have problem you can contact our support we will remote update for you
Return to MOI Pro - AMD
