[ Moderator Control Panel ]
by krmlk » Fri Feb 19, 2021 5:23 pm
I am using 2x Moi pro AMD since 2016 and one of the MOI started to crash or restart without any reason. Sometimes it restarting own daily 2-3 times or crashing or shutting down itself.
For troubleshooting what should I do first?
krmlk
by steven » Sun Feb 21, 2021 9:17 am
Hi Sir
For the problem one MOIPro-AMD check the heat dissipation you can take out the tuner card and DDR and insert again
by krmlk » Tue Mar 02, 2021 5:09 pm
thanks you are right,
we have found the problem one of the internal fan has been corrupted and should change. How we can organise it?
krmlk
by steven » Wed Mar 03, 2021 5:47 pm
Hi sir
Please send email to our
support@tbsdtv.com and take some picture tell us which FAN have issue
Return to MOI Pro - AMD
