TVHeadend crashes due to the 2.0.0.6 version
Postby SPiKeGoD » Wed Sep 04, 2019 9:48 am
I have updated the server to the version 2.0.0.6 and i have lost all my tvheadend data but I have configured everything again
This update also have updated the tvheadend to the "4.3-1789~g6bfeca6" version
the problem is when i turn a HD Sat Channel the tvheadend shows the message: "There seems to be a problem with the live update feed from Tvheadend. Trying to reconnect..." and crashes...
With the previous version 2.0.0.2 i could to use this channels without any problem....
Can you help me, please?
Thanks a lot in advance
SPiKeGoD
Re: TVHeadend crashes due to the 2.0.0.6 version
Postby SPiKeGoD » Wed Sep 04, 2019 10:15 am
The problem only happens when i turn a encrypted HD Channel, with SD no problem
I use OSCam
SPiKeGoD
Postby xiaocao » Wed Sep 04, 2019 11:41 am
hi ,
please delete the confguration of the tvheadend . "rm -rf /root/.hts/tvheadend" and reset tvheadend to check ,
different tvheadend use different configuration file .
best regardS!
xiaocao
Postby SPiKeGoD » Wed Sep 04, 2019 9:34 pm
Thanks @xiaocao but it was unable to do it works
I restore to 2.0.0.4 but the problem now... is that the card TBS6209 does not appear... the cards TBS6909 and TBS6301 appear!
SPiKeGoD
Return to MOI Pro - AMD
Users browsing this forum: Google [Bot] and 5 guests
