How to reset memory counter
Postby johnnysamu » Wed May 22, 2019 4:08 pm
In TVHeadEnd there is a counter at the top, which shows how much space is in the memory. In mine it now stands 0,0,0. I cannot record because there is no memory left, I have connected to an external hard drive. Something is wrong when calculating disk space, even if I clean. Someone who has ideas? maybe some file with memory numbers that can be changed?
How to force a new calculation?
/Johnny
johnnysamu
Re: How to reset memory counter
Postby xiaocao » Fri May 24, 2019 10:35 am
hi ,
you mean can't record ts to external hard driver ?
best regards!
xiaocao
Postby johnnysamu » Fri May 24, 2019 11:48 pm
Hello!
I can record on external hard drive in my network, normally. But my inclination for it was made after the counter in TVHeadEnd hit bottom 0.0.0. Image
fstab looks like ...
//192.168.1.1/TvSerier/recordings2/ /mnt/recordings2/ cifs rw,credentials=/etc/$
Somehow, it seems that memory doesn't change for the better. There should be some file that I can change the content to get better memory report to TVHeadEnd.
/sincerely Johnny
johnnysamu
Return to MOI Pro - AMD
