System corruption after yum update
Postby SPiKeGoD » Wed Sep 19, 2018 3:34 am
Hello!
I have made a yum update and now it is impossible to run OpenSSH,openssl, ...
The error is:
ssh: /lib/libcrypto.so.10: version `OPENSSL_1.0.2' not found (required by ssh)
openssl: /lib/libcrypto.so.10: version `OPENSSL_1.0.2' not found (required by openssl)
I tried to make a yum history rollback and a yum history undo but it was not possible to solve the problem.
I tried to erase and reinstall openssh-server and openssl but it is the same...
My Centos version is:
[root@localhost tmp]# hostnamectl
Static hostname: localhost.localdomain
Icon name: computer-laptop
Chassis: laptop
Machine ID: 0606f6f6ea0347c59f401379a356de18
Boot ID: cabfe854cbce4e208b229988663e9939
Operating System: CentOS Linux 7 (Core)
CPE OS Name: cpe:/o:centos:centos:7
Kernel: Linux 3.10.0-862.11.6.el7.x86_64
Architecture: x86-64
SPiKeGoD
Re: System corruption after yum update
Postby esimotas » Mon Sep 24, 2018 11:41 pm
Doing
# which openssl
/usr/bin/openssl
# ldd /usr/bin/openssl
/usr/bin/openssl: /lib/libcrypto.so.10: version `OPENSSL_1.0.2' not found (required by /usr/bin/openssl)
Openssl is trying to find libcrypto.so.10 in /lib folder - it should be looking in /lib64 folder (or /usr/lib64 ).
Quick fix: tell linker to look into /lib64 for openssl libs
# echo "/lib64" > /etc/ld.so.conf.d/openssl.conf
# ldconfig
You should now be able to run openssl. Do similar approach for ssh.
esimotas
Return to MOI Pro - AMD
