Problems with stream from MOIPro AMD
Postby fr34k » Sat Dec 09, 2017 9:31 pm
I have MOIPro AMD, and I have subscription at Xtream Codes for the panel, but my problem is as this.
When I stream directly from my MOIPro AMD to my friend's SmartTV it works perfectly, but when I try doing it over Xtream Codes panel it won't run/start with more than op till 10 streams.
What can it be a problem?
I have disabled all transcoders in Tvheadend.
Regards,
fr34k
fr34k
Re: Problems with stream from MOIPro AMD
Postby steven » Mon Dec 11, 2017 11:03 am
Hi fr34k
What about your tvheadend setting make sure that you disable the network discover and one tuner one network one muxes , as one tuner only can support transponder at the same time .
so make sure your setting is right .
Return to MOI Pro - AMD
Users browsing this forum: Google [Bot] and 3 guests
