Server can't handle the stream
Postby krmlk » Wed Sep 27, 2017 9:45 pm
Astra cesbo works on MOI PRo
total channels about 30, 10 HD and 20SD channel. I am sharing the duty between die network interfaces but some streams make problem and I found the problem that the system can't handle this:
here is the ifconfig
enp1s0f0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.35 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::222:abff:fe80:1da9 prefixlen 64 scopeid 0x20<link>
ether 00:22:ab:80:1d:a9 txqueuelen 1000 (Ethernet)
RX packets 7442836056 bytes 491747971485 (457.9 GiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 22418754863 bytes 32556152371294 (29.6 TiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
enp2s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.59 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::222:abff:fe80:1dd5 prefixlen 64 scopeid 0x20<link>
ether 00:22:ab:80:1d:d5 txqueuelen 1000 (Ethernet)
RX packets 408577 bytes 25325804 (24.1 MiB)
TX packets 10 bytes 744 (744.0 B)
It seems enp1s0f0 pushing itself to send all stream data but am sending the %50 of streams enp2s0: (192.168.1.59)
How can I fix the problem?
krmlk
Re: Server can't handle the stream
Postby steven » Thu Sep 28, 2017 9:33 am
Maybe try LACP to share the interfaec with one IP : )
Return to MOI Pro - AMD
