update from MOIPro-AMD Version 1.0.0.3
Postby krmlk » Fri Sep 08, 2017 3:31 pm
Dear all
I would like to ask that I am planning to update my device because of tvheadend crasdhes but I don't know after the update everything works. Should I backup the settings of tvheadend and cesbo before the update?
krmlk
Re: update from MOIPro-AMD Version 1.0.0.3
Postby xiaocao » Mon Sep 11, 2017 3:22 pm
hi ,
if current tvheadend crashed , i suggest you to install a stable version of tvheadend . because different tvheadend use different configuration files .
there is no useful to back up the current tvheadend .
#wget https://dl.bintray.com/tvheadend/centos/linux/4.2/el7.centos/x86_64/tvheadend-4.2.3-20~g407c8a3.el7.centos.x86_64.rpm
#rm -rf /usr/share/tvheadend /usr/bin/tvheadend /root/.hts/
#rpm -e --nodeps tvheadend
#yum install uriparser-devel.x86_64
#rpm -ih tvheadend-4.2.3-20~g407c8a3.el7.centos.x86_64.rpm
#reboot
cesbo's configuration file will also exist after update.
best regards!
xiaocao
Postby krmlk » Thu Sep 14, 2017 5:36 pm
Thanks for the information. I followed your tutorial and have been installed tvheadend but after 3 days it has been crashed again. So I think TVH is not a suitable for ıPTV projects. Cesbo and mumudvb are best stabile solutions imo
krmlk
Return to MOI Pro - AMD
