How many simultaneous channels
Postby decibel83 » Thu Jul 27, 2017 6:26 am
How many channels (DVB-T or DVB-S) does the MOI Pro AMD system can stream in the same time at SD resolution (720 x 576) and in HD resolution (1080p), supposing I will use both gigabit network cards in bonding (so connected to two separate switches with LACP activated)?
Thank you very much!
Bye
decibel83
Re: How many simultaneous channels
Postby steven » Sat Jul 29, 2017 3:37 pm
Hi decibel83
Thanks for your interest of our product ,for MOIPro-AMD we have tested streaming about 400 SD FTA channels with two Ethernet interface multicast udp , dvblast software , for HD FTA the numbers will half about 200 or less .
one Ethernet output ability is about 800Mbps so you can calculate how much it can streaming depend on the channels data rate .
for unicast http test with tvheadend it will about 150 client and channels .as http cost some CPU resource
any more question please feel free to ask us .
Return to MOI Pro - AMD
Users browsing this forum: Google [Bot] and 2 guests
