tbs6205 driver dvb-c
Postby DCM2016 » Thu May 25, 2017 12:53 am
I have a moi pro with 3x tbs6910 and 1 tbs6205.
the 3 tbs6910 is perfect. but the tbs6205 find only dvb-t/t2 signal. i need dvb-c.
I have read and tried to install drivers for dvb-c. Unfortunately without success Can I please tell me how I can install a driver for dvb-c for the tbs6205?
Thanks, people
DCM2016
Re: tbs6205 driver dvb-c
Postby steven » Wed May 31, 2017 6:08 pm
For MOIPro-AMD which firmware you are using ? please try latest firmware v2.0.0.x which support
6205 using DVB-T and DVB-C at the same time .
chekc this user guide :
https://www.tbsiptv.com/download/tbs620 ... _guide.pdf
make sure that you are using the latest open source driver you can use this one :
#wget http://www.tbsdtv.com/download/document/linux/media_build-latest.tar.bz2
#tar jxvf media_build-latest.tar.bz2
#cd media_build
#./install.sh
#reboot
Return to MOI Pro - AMD
Users browsing this forum: Google [Bot] and 2 guests
